BT.com
Wishlist
Acer RT270bmid 27" 1920x1080 4ms VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
An Acer RT0 monitor looks remarkably slim, because it's thinner and it also has a very thin frame. This minimalist beauty combines with the elegance of the T-shaped metal stand for a stylish monitor, that fits seamlessly in any space.
Acer RT270 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
62.1 cm x 19.62 cm x 45.38 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class A+
31 kWh
21 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Flicker-Less technology, Blue Light Filter technology, 6-bit gamma
62.1 cm x 19.62 cm x 45.38 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
30 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 62.1 cm - depth: 19.62 cm - height: 45.38 cm , Without stand - width: 62.1 cm - depth: 3.37 cm - height: 37.17 cm
ENERGY STAR Certified
Scroll to top
