BT.com
Wishlist
Acer Predator X34 34" 3440x1440 4ms HDMI DP USB IPS Monitor
Delivery
Standard Due date unavailable
The 34-inch curved 21:9 ultra-wide Predator X34 monitor (formally known as the XR341CKA) is a curved monitor with NVIDIA G-SYNC, providing an immersive gaming experience with minimal stutters and screen tears. It features DTS sound, 2x7W speakers, a zero-frame design with a futuristic aluminum base and ambient lighting options create an exciting entertainment experience with style. The Predator X34's UltraWide QHD (3440 x 1440) IPS panel has a 178-degree viewing angle, and also features flicker-less technology to lessen eye fatigue for a more comfortable gaming or working experience.
Acer Predator X34 - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
93 kWh
Curved Screen
Adaptive-Sync Technology
NVIDIA G-SYNC, VESA Adaptive-Sync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440 at 75 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
EMEA
Microsoft Certification
Compatible with Windows 7
TCO Displays 6.0
2 years warranty
Display Type
Energy Class
Class C
93 kWh
Diagonal Size
34"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, ambient light sensor, picture by picture, Acer Adaptive Contrast Management (ACM), ultra wide viewing angle, 100% sRGB colour gamut, Zero Frame, Flicker-Less technology, 6-axis colour adjustment, Blue Light Filter technology, DTS Sound
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+35
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Charging via USB, VESA interface support, Acer Eyeprotect technology, Acer ColorPlus technology
Stand
1 x HDMI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
TCO Displays 6.0
EMEA
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
