BT.com
Wishlist
Acer P7215 DLP XGA 6000 Lumens Projector
Delivery
Standard Due date unavailable
This projector is very eco-friendly, delivering light for up to 2,000 hours while using 350 watts, reducing power consumption and maintenance costs.
Acer's P7215 comes with convenient settings and upgraded features that improve usability and presentation flexibility. It features native 1024x768 (XGA) resolution and support for up to Full HD signal, delivering crisp, vibrant details and amazing color. In addition, this projector is DLP 3D Ready and offers advanced firmware that enables high refresh rates (120 Hz) to render flicker-free 3D experience.
The P7215 also boasts Crestron network control and connectivity options such as HDMI, DVI, LAN and dual D-Sub ports, making it a high impact tool for professional users in large venues. Furthermore, with Acer's top-loading lamp design, users can replace the lamp in just a few simple steps, even when the projector is ceiling-mounted.
Acer P7215 DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Microdisplay
DarkChip 2
Brightness
6000 lumens
Contrast Ratio
2100:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
P-VIP 330 Watt
Bulb life cycle
Up to 1500 hour(s) / up to 2000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G )
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V
435 Watt
39.8 cm x 30.9 cm x 12.6 cm
7.1 kg
2 years warranty
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Projector
Microdisplay
DarkChip 2
Brightness
6000 lumens
Brightness (Reduced)
4800 lumens
Contrast Ratio
2100:1
Image Size
64 cm - 762 cm
Projection Distance
1.2 m - 12.2 m
Throw Ratio
2.0 - 2.4:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 330 Watt
Bulb life cycle
6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, BrilliantColor, ColorBoost II+ Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Crestron RoomView, Auto Power Off
Lens
Focus Type
Manual
Lens Aperture
F/1.77-1.93
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
5 Watt
Speakers
2 x right / left channel
Input Device
External
Movement Detection Technology
Infrared
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 1 x audio line-out - mini-phone 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x DVI-I input - 29 pin combined DVI , 3 x audio line-in - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
Security lock slot (cable lock sold separately), PIN code
TUV GS, FCC, ROSTEST
Nominal Voltage
AC 120/230 V
435 Watt
Power Consumption Operational (Standby)
1 Watt
39.8 cm
30.9 cm
12.6 cm
7.1 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year , Limited warranty - DLP chipset - 5 years
5 °C
Sound Emission
34 dBA
30 dBA
Accessories
£7.20
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£38.41
£52.03
Scroll to top
