BT.com
Wishlist
Acer P3250 DLP XGA 2000 Lumens
Delivery
Standard Due date unavailable
Weighing only 1.2 kg (2.7 lbs.), the P3250 projector is an ultra-lightweight powerhouse casting 2000 ANSI Lumens brightness, and boasting native XGA (1024 x 768) resolution for high-impact projection performance.
An HDMI™ port offers advanced digital connectivity to a variety of media sources. Acer ColorBoost and SmartFormat technologies provide brilliant, professional imaging and support for both 4:3 displays and widescreens, delivering superior enterprise-level presentations.
With up to 5000 hours of lamp life, the P3250 saves lamp replacement costs and ensures long-term, dependable projector use.
Compact projection
  • Unique, elegant design
  • Acer ColorBoost Technology
  • XGA resolution
  • 2000 Lumens brightness and 2000:1 contrast ratio
  • DLP® system design
Ample usability
  • Acer eView Management
  • Acer eTimer Management
  • Acer eOpening Management
  • Acer SmartFormat Technology
  • Acer InstantPack technology
  • Automatic safety shutdown
  • Quick signal detection
Reliable connectivity
  • Digital connectivity via an HDMI™ port
  • Multi-PC Connectivity
  • Windows Vista® compliance
Effective functionality
  • Longer lamp life (5000 hours)
  • ECO Mode
  • Keystone correction (40° vertical)
  • Digital zoom and pan
  • PIN security
  • Bulit-in speaker
  • Alarm
  • PIN Security
Acer P3250 Eco DLP projector
DLP projector
Built-in Devices
Speaker
Brightness
2000 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
134.2 million colours
Bulb type
P-VIP 165 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G )
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V
235 Watt
21 cm x 16.5 cm x 6.4 cm
1.2 kg
2 years warranty
DLP projector
Built-in Devices
Speaker
Projector
Brightness
2000 lumens
Brightness (Reduced)
1500 lumens
Contrast Ratio
2000:1
Image Size
58 cm - 762 cm
Projection Distance
1 m - 11.9 m
Throw Ratio
1.95 - 2.15:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 100 kHz
Bulb type
P-VIP 165 Watt
Bulb life cycle
Eco-Mode technology, 6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), ColorBoost II Technology
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Input Device
External
Movement Detection Technology
Infrared
1 x USB - 4 PIN USB Type B ( management ) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x component video cable , 1 x VGA cable
Nominal Voltage
AC 120/230 V
235 Watt
Power Consumption Operational (Standby)
5 Watt
21 cm
16.5 cm
6.4 cm
1.2 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 90 days
Sound Emission
36 dBA
29 dBA
Scroll to top
