BT.com
Wishlist
Acer P1276 DLP XGA 3500 Lumens Projector
Delivery
Standard Due date unavailable
Deliver your bright ideas effectively with an Essential series projector. Fine visuals and easy-to-use, long-lasting technology help you maximize the power of your thoughts, while adhering to your bottom line.
Acer P1276 DLP projector - 3D
DLP projector
3D Capable
Brightness
3500 lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G )
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50 - 60 Hz )
305 Watt
28.8 cm x 22.5 cm x 8.3 cm
2.4 kg
DLP projector
3D Capable
Projector
Brightness
3500 lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
58.4 cm - 762 cm
Projection Distance
1 m
Throw Ratio
1.95 - 2.15:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 ( management ) , 1 x USB - 4 pin mini-USB Type B
Carrying case, remote control
1 x VGA cable
Nominal Voltage
305 Watt
Power Consumption Stand by
0.5 Watt
28.8 cm
22.5 cm
8.3 cm
2.4 kg
5 °C
Scroll to top
