Click to visit BT.com
BT.com
Wishlist
Acer K750 DLP Hybrid LED/Laser 1200 Lumens Projector
Quicklinx: 8R6DWS00
Mfr#: MR.JEH11.001
The Acer K750 is the world's first 1080p projector equipped with a hybrid laser-LED light technology, improving color saturation by 55% to deliver outstanding, energy efficient projection.
The K750 projector uses both LED and laser light sources, which is not only hazardous substances free - like mercury of halogen gases - but also significantly improves color brightness when compared to high-pressure mercury lamps. This technology also increases the light-source lifetime to 20,000 hours in ExtremeECO mode and enables as much as 90% power savings, helping to reduce TCO over its life, thus positioning the K750 as one of the most environmental friendly projectors.
What's more, this innovative hybrid light-source technology enables flexible color settings and a wider color gamut to deliver better color saturation up to 85% NTSC and offers superior color fidelity through a system of three independent color lighting sources. With a brightness of up to 1,500 lumens and a contrast ratio up to 100,000:1 projects perfect and crispy content, while the 1080p Full HD resolution allows enjoying HDTV and watching Blu-ray movies in fantastic clarity and detail.
The HDMI port delivers uncompressed digital signals and multi-channel audio, providing easy connectivity to high-definition presentation and entertainment. In addition to it, the K750 projector is equipped with at least two connectors for multiple-PC source input, including D-Sub and HDMI, offering more flexible connectivity and instant switching.
In order to empower usability, the K750 features instant on/off capability, which means no cool-down period is needed after turning the projector off. This is an important productivity feature especially in the business and education world. Moreover, the Acer SmartFormat technology instantly synchronizes with wide-format displays without any resolution adjustments from the notebook, while supporting multi-format for instant projection.
This projector sports an elegant gray-and-white portable design: the control pad is embedded on the sleek gray and metal surface, reflecting Acer's premium craftsmanship; the sculpted lines on the ventilation grill add sophistication to the design, while the smooth, rounded contours provide a comfortable touch.
Acer K750 DLP projector
DLP projector
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
1500 lumens
Contrast Ratio
100000:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, S-Video, composite video ( PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G )
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
215 Watt
32.1 cm x 23.1 cm x 8.7 cm
4.04 kg
DLP projector
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
1500 lumens
Brightness (Reduced)
1200 lumens
Contrast Ratio
100000:1
Image Size
96 cm - 762 cm
Projection Distance
1.5 m - 10 m
Throw Ratio
1.65:1
Uniformity
95 %
Digital Zoom Factor
8x
Resolution
Full HD - 1920 x 1080
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
85 Hz x 100 kHz
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Picture in picture, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, ColorBoost II+ Technology, instant shutdown, SmartFormat Technology, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/2.55-2.86
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
Input Device
External
Movement Detection Technology
Infrared
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x S-video input - 4 PIN mini-DIN , 1 x serial RS-232 - mini-DIN ( management )
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
Security lock slot (cable lock sold separately), PIN code
Nominal Voltage
AC 120/230 V
215 Watt
Power Consumption Operational ( Standby )
0.5 Watt
32.1 cm
23.1 cm
8.7 cm
4.04 kg
5 °C
Sound Emission
30 dBA
27 dBA
