BT.com
Wishlist
Acer K272HLDbid 27" 1920x1080 1ms VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
Acer K272HL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
29 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Glossy black
64 cm x 23.5 cm x 46.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, MPR III, ISO9241-307
2 years warranty
Display Type
Energy Class
Class A
43 kWh
29 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Screen Coating
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, ComfyView
Glossy black
64 cm x 23.5 cm x 46.3 cm - with stand
5 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
Stand
1 x VGA cable
MTBF
30,000 hours
23.5 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
ENERGY STAR Certified
Scroll to top
