BT.com
Wishlist
Acer K242HLbd 24" Full HD LED DVI VGA W/HDCP Monitor
Delivery
Standard 3-5 working days
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor deliv ers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CC FL lamps. In addition, this monitor is mercury-free, ma king it safer for you and the environment.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by fram e, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
Acer Eco-Display
As part of our commitment to sustainable operations an d corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Display
  • 24" Screen
  • TN Panel
  • LED Backlight
  • Resolution: 1920 x 1080 @60Hz Full HD
  • Response Time: 5ms
  • Contrast ratio: 100,000,000:1
  • Brightness: 250 cd/m2
  • Viewing angle: 170°/ 160°
  • Display Colours: 16.7m
  • VGA
  • DVI
  • Tilt range: -5° to +25°
  • HDCP Supported
  • Anti-Glare
  • VESA 100 x 100
Acer K242HLbd - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Glossy black
56.7 cm x 20.68 cm x 42.22 cm
3.57 kg
United Kingdom, Europe, EMEA
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
Glossy black
56.7 cm x 20.68 cm x 42.22 cm - with stand
3.57 kg
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
MPR II
Power Supply
Internal
6 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
Accessories
£7.96
£8.85
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.90
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£41.59
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.38
£56.05
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Failed 15 months after purchase.
Reviewed by Robert Hutchings on 11/10/2015
Good price and the monitor was good whilst it worked. But as the title says 15 months after purchase the monitor has stopped worked and now only displays and entirely white screen.
Granted acer are a budget brand but I expected the monitor to last longer than 15 months. I won't be buying any of there products in the future.
Scroll to top
