BT.com
Wishlist
Acer K222HQLDbd 21.5" 1920x1080 VGA DVI Monitor
Delivery
Standard Due date unavailable
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
50.8 cm x 20.8 cm x 39.1 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, Acer eColor technology, Flicker-Less technology
50.8 cm x 20.8 cm x 39.1 cm - with stand
3.6 kg
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
MPR II
19.7 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.8 cm - height: 39.1 cm - weight: 3.6 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.2 kg
ENERGY STAR Certified
Scroll to top
