BT.com
Wishlist
Acer K222HQL 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Delivery
Standard Due date unavailable
Expand your vision
- 21.5" Display with Full HD resolution
- Stunning colors
- Connecting features
- Ergonomic stand tilts from -5 to 25 degrees
- Environmentally friendly
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail,
making it perfect for advanced HD productivity and multimedia applications.
LED monitors also consume less power and last longer than those with CCFL
lamps. In addition, this monitor is mercury-free, making it safer for you
and the environment.
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors,
reduced glare and more comfortable viewing, even over prolonged periods.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the
highest level of clarity and detail by analyzing every scene, adjusting
images frame by frame, and enhancing detail and gradation. In addition, with
ACM, the LCD monitor uses less power.
Acer Eco-Display
As part of our commitment to sustainable operations and corporate social
responsibility, Acer uses methods to carry out product design and material
management distinctly meant to reduce environmental impact.
Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
18.1 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
50.8 cm x 20.7 cm x 39.05 cm
3.1 kg
Microsoft Certification
Compatible with Windows 7
MPR II, TUV, GS, ISO9241-307
2 years warranty
Display Type
Energy Class
Class A
29 kWh
18.1 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
110
Vertical Viewing Angle
85
Backlight Technology
LED backlight
Acer EcoDisplay, 72% NTSC colour gamut, ComfyView
50.8 cm x 20.7 cm x 39.05 cm - with stand
3.1 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hour(s)
Power Supply
Internal
AC 120/230 V
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.05 cm - weight: 3.1 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 2.7 kg
Accessories
Accessories
£138.85
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.23
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.23
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£57.19
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.40
StarTech.com Monitor Arm - Heavy Duty
Quicklinx: CRY1 | In Stock
£87.34
Other bundles
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
Scroll to top
