BT.com
Wishlist
Acer K132 WXGA DLP 500 Lumens Ultra Portable Projector
Delivery
Standard Due date unavailable
Some of your best ideas happen outside the boardroom - and you can share them when they happen with Acer Travel Series projectors. Discuss concepts and motivate others, even without a PC, wherever you go. With models as slim as 1" (24.5 mm), the world of self-expression is in your pocket.
Acer K132 - DLP projector
DLP projector - High Definition
Brightness
500 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s) / up to 30000 hour(s) (economic mode)
Speakers
Speaker(s) - integrated
AC 120/230 V
14 cm x 11.6 cm x 4.1 cm
420 g
2 years warranty
DLP projector - HD
Projector
Brightness
500 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
43.2 cm - 254 cm
Projection Distance
0.6 m
Digital Zoom Factor
1.7x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
Laser/LED
Bulb life cycle
Lens
Lens Aperture
F/2.0
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A
Nominal Voltage
AC 120/230 V
14 cm
11.6 cm
4.1 cm
420 g
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
