BT.com
Wishlist
Acer H236HLbmjd 23" IPS LED 1920x1080 DVI HDMI MHL Monitor
Delivery
Standard Due date unavailable
This Everyday series monitor saves space and adds elegance to any area. You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolutions, fast response times and superior contrast ratios. Games are more exciting and films truly cinematic when visuals are vibrant. Plus, the widescreen aspect ratio frames movies and HDTV content perfectly. Set your display as you see fit with Acer eColor Management. A host of ports, including HDMI, DVI, DisplayPort and VGA, let you connect other devices - like your notebook or HDTV - to expand your perspective to a bigger screen. The great sights are complemented by nice sound in models that include internal speakers. Safe for you and your world, Everyday Series use mercury-free white LED backlighting. Acer EcoDisplay technologies deliver up to 68% power savings, further conserving energy and costs. Acer packaging is made of recyclable materials too.
Acer H236HLbmjd - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Speakers
Integrated
53.09 cm
2.9 kg
MPR II
2 years warranty
Display Type
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Mobile High-Definition Link (MHL)
53.09 cm - without stand
2.9 kg
Audio
Speakers - integrated
VGA , DVI , HDMI
1 x VGA cable
MPR II
AC 120/230 V
26 Watt
Power Consumption Stand by
450 mW
Dimensions & Weight Details
With stand - width: 53.09 cm - depth: 17.27 cm - height: 40.39 cm - weight: 3.6 kg
Limited warranty - 2 years - carry-in
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
£17.48
Scroll to top
