BT.com
Wishlist
Acer GD245HQAbid - LCD display - 3D Ready - TFT - CCFL - 23.6" - widescreen - 1920 x 1080 - black
Delivery
Standard Due date unavailable
The Acer GD245HQ 3D monitor is full HD (1920 x 1080 pixels) LCD display with 120 Hz support and is certified for NVIDIA 3D Vision. To obtain the 3D effect the monitor displays the alternating left- and right-eye images, at a rate of 120 frames per second. An infrared signal beamed from the IR-emitter induces glasses worn by the viewer to alternately turn of the left and right lenses. The images alternately seen with each eye are combined in the brain, giving the viewer the impression of seeing.
Acer GD245HQAbid - 3D LCD monitor - 23.6"
LCD monitor - 23.6"
3D Capable
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Brightness
300 cd/m²
Contrast Ratio
80000:1 (dynamic)
Response Time
2 ms
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
2 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
23.6"
3D Capable
3D Technology
Alternate-frame sequencing
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
80000:1 (dynamic)
Response Time
2 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
CCFL
HDCP, Four Lamps for Back Light, Acer Adaptive Contrast Management (ACM)
VGA , DVI-D (dual link) , HDMI
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, CCFL (cold cathode fluorescent lamp)
Limited warranty - 2 years - carry-in
Scroll to top
