BT.com
Wishlist
Acer G246HLGbid 24" 1920x1080 VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
Acer G6 Series monitors are incredibly stylish with a super-slim profile. Outstanding performance, eco-friendliness and smart use of energy complement the sleek design - all while staying well within budget.
Acer G246HLG - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
56.5 cm x 17.89 cm x 40.09 cm
3.83 kg
Environmental Standards
ENERGY STAR Qualified
2 years warranty
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Backlight Technology
LED backlight
Acer EcoDisplay, 6-bit gamma
56.5 cm x 17.89 cm x 40.09 cm - with stand
3.83 kg
VGA , DVI (HDCP) , HDMI
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Power Consumption (Off Mode)
450 mW
Dimensions & Weight Details
Without stand - width: 56.5 cm - depth: 2.37 cm - height: 34.27 cm , With stand - width: 56.5 cm - depth: 17.89 cm - height: 40.09 cm - weight: 3.83 kg
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
Scroll to top
