BT.com
Wishlist
Acer G237HLAbid 23" 1920x1080 4ms VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
The futuristic style of the G7 Series incorporates a slim zero frame design that saves space on your desk and lets you place multiple G7 monitors side by side to build a seamless big-screen display. You can pick the color that fits your style and you can tilt the display from -5 to 15 degrees, for comfortable viewing.
Acer G237HL - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
53.2 cm x 18.5 cm x 40.2 cm
3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II, RoHS
2 years warranty
Display Type
Energy Class
Class A
31 kWh
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
CrystalBrite, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), Zero Frame, Mercury free
53.2 cm x 18.5 cm x 40.2 cm - with stand
3 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Stand
1 x VGA cable
MPR II, RoHS
Power Supply
External
25 Watt
Power Consumption Stand by
490 mW
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 18.5 cm - height: 40.2 cm - weight: 3 kg , Without stand - width: 53.2 cm - depth: 4.07 cm - height: 32.2 cm - weight: 2.7 kg
ENERGY STAR Certified
Scroll to top
