BT.com
Wishlist
Acer G226HQL 21.5" 1920x1080 2ms DVI HDMI VGA LED Monitor
Delivery
Standard Due date unavailable
Everyday Series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer G226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
51.06 cm x 16.92 cm x 36.45 cm
2.04 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
75 Hz
Horizontal Viewing Angle
100
Vertical Viewing Angle
70
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, 72% NTSC colour gamut
2.04 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MTBF
30,000 hour(s)
MPR II
Power Supply
Internal
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 51.06 cm - depth: 16.92 cm - height: 36.45 cm , Without stand - width: 51.06 cm - depth: 1.4 cm - height: 31.2 cm
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
Accessories
£8.23
£9.21
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.33
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£43.94
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.73
£59.23
Scroll to top
