BT.com
Wishlist
Acer ED322Q 31.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
Acer ED322Q 31.5" 1920x1080 4ms VGA...
£252.79
Select:
£252.79
Add to wishlist
Delivery
Standard Due date unavailable
Immerse yourself in the graphics of work or play on this Acer curved monitor. The edge-to-edge frameless screen is a full 31.5 inches, wrapping you within the action of your favorite games and streaming movies. EyeProtect Flicker-Less and BlueLightShield technology on this Acer curved monitor defend your eyes from strain.
What's in the box
  • Acer ED322Q
  • VGA cable
Acer ED322Q - LED monitor - curved - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White
71.1 cm x 20.8 cm x 52.6 cm
5.86 kg
FCC Class B certified, MPR II, UL, TUV, VCCI, cUL, GS, NOM, RoHS, WEEE, EAC
Display Type
Energy Class
Class B
62 kWh
42 W
Diagonal Size
31.5"
Curved Screen
Yes (1800R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Acer BluelightShield technology
White
71.1 cm x 20.8 cm x 52.6 cm - without stand
5.86 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
35 Watt
Power Consumption (Off Mode)
1 Watt
On / Off Switch
No
Scroll to top
