BT.com
Wishlist
Acer CB271HK 27" 3840x2160 4ms Wide 4K UHD IPS DVI LED Monitor
Delivery
Standard Due date unavailable
Marketing description is not available.
Acer CB271H - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI/MHL: 60 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
DVI-D, DisplayPort, HDMI (MHL)
Display Position Adjustments
Height, pivot (rotation), tilt
62.4 cm x 23.7 cm x 54.4 cm
7.9 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class C
88 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Backlight Technology
LED backlight
62.4 cm x 23.7 cm x 54.4 cm - with stand
7.9 kg
Audio
Speakers
DVI , MHL / HDMI , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x DVI cable
TCO Displays 6.0
60 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
Without stand - width: 62.4 cm - depth: 6.4 cm - height: 37 cm - weight: 4.99 kg , With stand - width: 62.4 cm - depth: 23.7 cm - height: 54.4 cm - weight: 7.9 kg
ENERGY STAR Certified
Scroll to top
