BT.com
Wishlist
Acer CB270HU 27" 2650x1440 6ms DVI HDMI DP IPS LED Monitor
Delivery
Standard Due date unavailable
The Acer Prosumer series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Acer CB270HU - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Speakers
Integrated
Display Position Adjustments
Black glossy with silver ring on footstand
63.97 cm x 24.47 cm x 55.81 cm
7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV, GS, TCO Displays 6.0, ISO9241-307
3 years warranty
Display Type
Energy Class
Class B
61 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
108.8
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
23 - 76 Hz
Horizontal Refresh Rate
15 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, ComfyView, 100% sRGB colour gamut, Hard Coating (3H), daisy chain compatible
7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable
MTBF
30,000 hour(s)
Power Supply
Internal
AC 120/230 V
28.4 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
400 mW
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 24.47 cm - height: 55.81 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
