BT.com
Wishlist
Acer B276HULA 27" 2560x1440 6ms DVI HDMI DisplayPort USB LED Monitor
Delivery
Standard Due date unavailable
Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
Acer B276HUL - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
64 cm x 24.7 cm x 55.8 cm
8.51 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
66 kWh
45 W
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
64 cm x 24.7 cm x 55.8 cm - with stand
8.51 kg
Audio
Speakers
2 x HDMI , DVI-D , DisplayPort , 2 x USB 3.0 , DisplayPort output , 2 x USB , Audio line-in
1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
TCO Displays 6.0
AC 120/230 V
32.8 Watt
Power Consumption Stand by
490 mW
Power Consumption Sleep
350 mW
On / Off Switch
Dimensions & Weight Details
With stand - width: 64 cm - depth: 24.7 cm - height: 55.8 cm - weight: 8.51 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 6 kg
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
