BT.com
Wishlist
Acer B246HYLAymdr 23.8" 1920x1080 VGA DVI Monitor
Delivery
Standard Due date unavailable
Ideal for use in office environments, libraries and computer labs, this B6 monitor delivers dynamic and energizing visuals thanks to its high display resolution and true-to-life colors. It also features an ergonomic design for comfortable all-day computing, and it uses eco-friendly technologies to save power and cut energy costs.
Acer B246HYLA - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Screen Coating
Anti-glare
Dark grey
55.4 cm x 22.1 cm x 37.9 cm
Environmental Standards
ENERGY STAR Qualified
GS, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
31 kWh
22 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
92.6
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
ErgoStand, 72% NTSC colour gamut, ComfyView
Dark grey
55.4 cm x 22.1 cm x 37.9 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
1 x VGA cable - 1.5 m , 1 x DVI cable - 1.5 m , 1 x audio cable - 1.5 m
MTBF
30,000 hour(s)
Power Consumption Stand by
0.21 Watt
Power Consumption Sleep
0.23 Watt
Power Consumption (Off Mode)
0.21 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.4 cm - depth: 1.9 cm - height: 37.9 cm , With stand - width: 55.4 cm - depth: 22.1 cm - height: 37.9 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
Scroll to top
