BT.com
Wishlist
Acer B246HYL 23.8" 1920x1080 6ms VGA DVI Full HD Monitor
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
Acer B246HYL - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Dark grey
55.44 cm x 22.12 cm x 52.91 cm
6.42 kg
United Kingdom, Europe, EMEA
Environmental Standards
ENERGY STAR Qualified
GS, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
31 kWh
22 W
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, focus
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
72% NTSC colour gamut
Dark grey
55.44 cm x 22.12 cm x 52.91 cm - with stand
6.42 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , DisplayPort
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
MTBF
30,000 hour(s)
23 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
Without stand - width: 55.44 cm - depth: 5.2 cm - height: 33.1 cm - weight: 3.73 kg , With stand - width: 55.44 cm - depth: 22.12 cm - height: 52.91 cm - weight: 6.42 kg
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
Scroll to top
