BT.com
Wishlist
Acer B196LAwmdpr 19" 1280x1024 VGA DVI DP Monitor
Delivery
Standard Due date unavailable
Ideal for use in office environments, libraries and computer labs, professional series monitors deliver dynamic and energizing visuals. This monitor features eco-friendly technologies that save power and cut energy costs. It is also ergonomically designed, with a slim and clean-cut look.
Acer B196L - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
White
42.27 cm x 19.1 cm x 40.6 cm
5.3 kg
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
White
5.3 kg
Audio
Speakers
VGA , DVI , DisplayPort
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Height Adjustment
150 mm
Flat Panel Mount Interface
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
Dimensions & Weight Details
Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.76 kg , With stand - width: 42.27 cm - depth: 19.1 cm - height: 40.6 cm - weight: 5.3 kg
Limited warranty - 3 years
Scroll to top
