BT.com
Wishlist
Acer B196L 19" 1280x1024 5ms DVI LED Monitor
Delivery
Standard Due date unavailable
Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that savepower and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
What's in the box
  • Acer B196Lwmdr
  • VGA cable
  • DVI cable
  • Audio cable
Acer B196Lwmdr - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
White
51.92 cm x 22.1 cm x 40.64 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
GS, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Pixel Per Inch
86
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, focus
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
Acer EcoDisplay, 72% NTSC colour gamut
White
5.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
MTBF
30,000 hour(s)
Power Supply
Internal
15.8 Watt
Power Consumption Sleep
0.45 Watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
Scroll to top
