BT.com
Wishlist
Acer Aspire X3990 Core i3-2100 4GB RAM 500GB HDD DVDRW W7HP
Delivery
Standard Due date unavailable
  • Intel Core i3-2100 Processor
  • 4GB RAM
  • 500GB Hard Drive
  • DVD-RW Drive
  • HDMI Port
  • Windows 7 Home Premium
The sleek and compact Aspire X3 Series is just one-third the size of a traditional PC, allowing it to fit anywhere in your home. This desktop features high-quality components and software, perfect for handling your home computing and entertainment needs. Moreover, lots of multimedia features and device ports let you enjoy theater-quality entertainment right in your living room.
Features a HDMI® port, so you can connect your PC to big-screen peripheral displays, including your main home entertainment center.
With expandable DD3 memory, this desktop promises speedy multitasking while using 20% less power. Large storage capacity means you have ample room to keep all your files. And a multi-in-1 card reader and numerous USB ports make it easy to manipulate and share your files.
At just one-third the size of a traditional PC, this desktop is easy to set up. A small door at the bottom opens for easy access to USB ports, audio ports, and the multi-in-1 card reader. What's more, the power button lights up in bright blue when turned on, so it looks cool and is easy to find.
Acer Aspire - SFF - Core i3 2100 3.1 GHz - 4 GB - 500 GB
Personal computer - small form factor
1 x Intel Core i3 2100 / 3.1 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB DDR3 SDRAM - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
1 x 500 GB - SATA 3Gb/s
Graphics Controller
Intel HD Graphics 2000
GigE
10 cm x 36.7 cm x 27 cm
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H61 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Unbuffered
Hard Drive
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Graphics Controller
Integrated
Graphics Processor
Input Device
Mouse, keyboard
Integrated
Power supply
10 cm
36.7 cm
27 cm
Scroll to top
