BT.com
Wishlist
Acer 27" 1920x1080 4ms VGA DVI HDMI LED Monitor
Delivery
Standard Due date unavailable
The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare and harsh blue light. Easy adjustments and a wide viewing angle help you find the perfect position.
Acer KA270H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
64 cm x 20 cm x 47.89 cm
Italy
Microsoft Certification
Compatible with Windows 7
MPR II, FCC Part 15, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN 50564:2011, Directive 1275/2008/EC, EN55024:2010, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, IEC 62301:2011, EN55022:2010 Class B
3 years warranty
Display Type
Energy Class
Class C
59 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, clock, focus, blue reduction
eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
64 cm x 20 cm x 47.89 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Stand
1 x VGA cable
Italy
25.8 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 64 cm - depth: 20 cm - height: 47.89 cm , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm
Limited warranty - 3 years
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.52
£52.15
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.19
Scroll to top
