BT.com
Wishlist
Accuratus Toughball 2 - 2.4GHz Wireless Multimedia Keyboard
Accuratus Toughball 2 - 2.4GHz...
£51.66
20 in stock
£51.66
Add to wishlist
Delivery
Standard 3-5 working days
Toughball 2, beautiful close up, even better from a distance... From its special coating to its pin sharp optical trackball, the Toughball 2 is a product of beauty. Hook the Toughball up to a PC with an LCD projector and be staggered at its wireless range. Use it with your media center and realize it works from all corners of the room or simply use it as a solid workhorse in the office. Either way the Toughball 2 will not disappoint.
Comfortable on and off the desk... Sooner or later you will want to sit back at your desk - only then will you appreciate the sculptured underside and newly designed contoured thumb areas. Its subtle curves will lock the keyboard on your lap making it far easier to work with than most flat keyboards. The Toughball 2 has a high resolution stainless steel trackball giving a very precise, extremely durable and reliable mouse movement.
Accuratus Toughball 2 - keyboard - UK
Keyboard - wireless
2.4 GHz
Wireless Receiver
USB wireless receiver
Layout
Hot Keys Function
Internet browsing, multimedia, My Computer, e-mail, volume, mute, mouse buttons, Windows 8
Integrated optical trackball, battery LED indicator, sleep mode
34.4 cm x 16.2 cm x 4.75 cm
600 g
Keyboard - wireless
2.4 GHz
Max Operating Distance
Up to 15 m
Wireless Receiver
Input Device
Hot Keys Function
Layout
34.4 cm
16.2 cm
4.75 cm
600 g
Plug and Play, FCC, RoHS, WEEE
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
AA type
Installed Qty
2
Scroll to top
