BT.com
Wishlist
3M Frameless Privacy Filter for 27" 16:9 Monitor
3M Frameless Privacy Filter for 27"...
£113.68
£113.68
Add to wishlist
Delivery
Standard 1-3 working days
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 27 1/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 23 9/16" wide x 13 1/4" high (598 mm x 337 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF27.0W9 - display privacy filter - 27" wide
Display privacy filter
Display Screen Size Compatibility
27" wide
59.8 cm 33.7 cm
1 year warranty
27" wide
59.8 cm 33.7 cm
Easy-to-remove
1 year warranty
Service & Support Details
Limited warranty - 1 year
Scroll to top
