BT.com
Wishlist
3M Anti-Glare Filter 21.5" Frameless
3M Anti-Glare Filter 21.5"...
Clearance
£23.98
Clearance
Last Few Remaining
Price Drop
Price Drop!
Hurry, only 2 left in stock!
£23.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 21 9/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 18 3/4" wide x 10 9/16" high (477 mm x 268 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG21.5W9 - display screen filter - 21.5" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
21.5" wide
1 year warranty
Package Content
Cleaning cloth
21.5" wide
Clear
Monitor Filter
Viewing Area Height
26.8 cm
Viewing Area Width
47.7 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 9XYN 034095
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£3.81
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
