BT.com
Wishlist
3M Anti-Glare Filter 19.5" Widescreen Frameless
3M Anti-Glare Filter 19.5"...
£55.59
Hurry, only 1 left in stock!
£55.59
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 19 7/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 17" wide x 9 5/16" high (433 mm x 237 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG19.5W9 - display screen filter - 19.5" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
19.5" wide
1 year warranty
Package Content
Cleaning cloth
19.5" wide
Clear
Monitor Filter
Viewing Area Height
24 cm
Viewing Area Width
43.2 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 9XYR 032361
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£7.80
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
