BT.com
Wishlist
3M 26.0" Widescreen (16:10) Monitor Privacy Filter - Frameless
Delivery
Standard Due date unavailable
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 25 9/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 21 11/16" wide x 13 9/16" high (551 mm x 344 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF26.0W - display privacy filter - 26" wide
Display privacy filter
Display Screen Size Compatibility
26" wide
55.1 cm 34.4 cm
1 year warranty
26" wide
55.1 cm 34.4 cm
Anti-reflective, easy-to-remove
1 year warranty
Service & Support Details
Limited warranty - 1 year
Scroll to top
