BT.com
Wishlist
3M 20" Widescreen Privacy Filter
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 20 3/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 17 1/8" wide x 10 11/16" high (434 mm x 272 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF20.1W - display privacy filter - 20.1" wide
Display privacy filter
Display Screen Size Compatibility
20.1" wide
20.1" wide
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
3M 20
Item condition Customer return - item has been used and shows signs of use
Ref: 5678 028182
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£10.29
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
