BT.com
Wishlist
3M 12.5" Widescreen Privacy Filter
£35.98
21 in stock
£35.98
Add to wishlist
Delivery
Standard 3-5 working days
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen laptops with a diagonally measured 12 1/2" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 10 15/16" wide x 6 1/8" high (277 mm x 156 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
3M Privacy Filter PF12.5W9 - notebook privacy filter
Notebook privacy filter
27.7 cm 15.6 cm
Display Screen Size Compatibility
12.5" wide
1 year warranty
27.7 cm
15.6 cm
12.5" wide
1 year warranty
Service & Support Details
Limited warranty - 1 year
Scroll to top
