BT.com
Wishlist
3Dconnexion CadMouse Mouse Pad
£33.40
1 in stock
£33.40
Add to wishlist
Delivery
Standard 3-5 working days
The 3Dconnexion CadMouse Pad provides the ideal balance between speed and control thanks to its high-quality micro-textured coating. It enables effortless, precise mouse movement thanks to perfect equilibrium between static and kinetic friction. That means your mouse moves exactly how you mean it to - every time.
3Dconnexion CadMouse - mouse pad
Mouse pad
Product Material
Silicone, rubber
25 cm x 35 cm
160 g
Mouse pad
Product Material
Silicone, rubber
25 cm
35 cm
Thickness
0.2 cm
160 g
Non-slip
Scroll to top
