BT.com
Wishlist
3D Systems Cube Pro Desktop 3D Printer - 3 Print Heads
3D Systems Cube Pro Desktop 3D...
£2,476.95
10 in stock
£2,476.95
Add to wishlist
Delivery
Standard 1-3 working days
The CubePro features build platform with ultra high-resolution. With ultra high-resolution settings of 70-micron thin print layers, professional quality printing has never been so large or easy.
CubePro will support nylon, along with strong ABS and compostable PLA plastic for production. Create functional prototype models or make end-use parts for your engineering applications. The CubePro is a versatile printer for both the engineer and hobbyist alike. Nylon is exceptionally durable for high heat resistance, high strength to weight ratio, or parts requiring secondary operations like painting, machining or adhesive bonding.
A controlled process environment ensures improved accuracy and reliability of print for effortless, professional quality every time for your largest ABS plastic prints. Automated settings ensure home-safe printing in your mancave, on your workbench and at your desktop.
3D Systems CubePro Trio - 3D printer
Printer Type
3D printer - FDM - 3 colour printing
38.5 kg
Max Build Size
270.4 x 200.4 x 230 mm
Build Speed
15 mm3/sec
Min Layer Thickness
70 µm
USB, Wi-Fi
Build Materials Supported
Polylactide (PLA), acrylonitrile butadiene styrene (ABS)
AC 120/230 V
Microsoft Windows 7, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3
57.8 cm x 57.8 cm x 59.1 cm
Printer Type
3D printer
Fused Deposition Modeling (FDM)
Multicolour Print
Yes (3 colour printing)
Printer
Build Speed
15 mm3/sec
Built-in Devices
Status LCD, touch screen
Wired
USB, Wi-Fi
Min Layer Thickness
70 µm
Input File Formats Supported
STL
Media Handling
Max Build Size
1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Power supply - internal
AC 120/230 V
System Requirements Details
2 GHz - RAM 2 GB
57.8 cm
57.8 cm
59.1 cm
38.5 kg
Scroll to top
