BT.com
Wishlist
3D Systems Cube Pro Cartridge PLA Green
3D Systems Cube Pro Cartridge PLA...
£70.66
£70.66
Add to wishlist
Delivery
Standard Due date unavailable
PLA (Polylactic Acid) is probably the easiest material to work with when you're first starting out with 3D printing. PLA is a biodegradable thermoplastic that has been derived from renewable resources like corn starch and sugar cane. This makes PLA environmentally friendly and very safe to work with.
PLA also has a very sharp glass transition point so if you use a fan to cool it, it will set into a solid very quickly. PLA can achieve a greater range of geometries than are possible with other plastics. It also reduces the thermal stress on the printed part, making warping less of an issue with larger PLA parts.
3D Systems - green - PLA filament
PLA filament
Printing Technology
Fused deposition modelling
Printing Colour
Green
Compatible with
3D Systems CubePro, CubePro Duo, CubePro Trio
Consumable
Consumable Type
PLA filament
Printing Technology
Green
Included Qty
1-pack
Compatible with
Scroll to top
