BT.com
Wishlist
3D Systems Cube Pro Cartridge PLA Gold
3D Systems Cube Pro Cartridge PLA...
£77.36
1 in stock
£77.36
Add to wishlist
Delivery
Standard 3-5 working days
The Cube prints in solid color ABS, with one color per cartridge. ABS (Acrylonitrile butadiene styrene) is considered the second easiest material to work with when you start 3D printing. The same kid-safe material that Legos are made of, ABS is also a strong and tough engineering polymer commonly used to produce car bumpers. Though durable, considerations must be made when printing larger objects as thermal stress can cause ABS to warp as the part cools. ABS is suitable for light, rigid, molded products with good shock absorption and wear resistance.
3D Systems Cube - gold - PLA filament
PLA filament
Printing Technology
Fused deposition modelling
Printing Colour
Gold
Compatible with
3D Systems Cube 3 Power Pack, CubePro, CubePro Duo, CubePro Power Pack, CubePro Trio
Consumable
Consumable Type
PLA filament
Printing Technology
Gold
Included Qty
1-pack
Compatible with
Scroll to top
