BT.com
Wishlist
3D Systems Cube Pro Cartridge PLA Brown
3D Systems Cube Pro Cartridge PLA...
£77.30
2 in stock
£77.30
Add to wishlist
Delivery
Standard 3-5 working days
ABS (Acrylonitrile butadiene styrene) is considered the second easiest material to work with when you start 3D printing. The same kid-safe material that Legos are made of, ABS is also a strong and tough engineering polymer commonly used to produce car bumpers. Though durable, considerations must be made when printing larger objects as thermal stress can cause ABS to warp as the part cools.
ABS is suitable for light, rigid, molded products with good shock absorption and wear resistance.
3D Systems - brown - PLA filament
PLA filament
Printing Technology
Fused deposition modelling
Printing Colour
Brown
Compatible with
3D Systems CubePro, CubePro Duo, CubePro Trio
Consumable
Consumable Type
PLA filament
Printing Technology
Brown
Included Qty
1-pack
Compatible with
Scroll to top
