BT.com
Wishlist
3D Systems Cube 3D Print Cartridge ABS - Blue
3D Systems Cube 3D Print Cartridge...
£38.66
£38.66
Add to wishlist
Delivery
Standard Due date unavailable
Bring your imagination to life in the colour of your choice with the Cubify ABS 3D Printer Cartridge.
Compatible with 2nd generation Cube 3D printers, this cartridge allows you to use ABS to print your own creations. Now you can let your creativity run wild.
It is simple to install the cartridges thanks to the click-in, click-out system, so you won't have to waste time trying to install it.
The cartridge will detect whether there is enough filament in the cartridge to complete your creation, alerting you to problems before you begin printing.
ABS is s petroleum based plastic. Whilst not entirely flexible, it considered more hard wearing and impact resistant than the more brittle PLA.
3D Systems Cube - blue - ABS filament
ABS filament
Printing Technology
FDM
Printing Colour
Blue
Compatible with
3D Systems Cube
Consumable
Consumable Type
ABS filament
Printing Technology
FDM
Blue
Included Qty
1-pack
Compatible with
3D Systems Cube
Scroll to top
