BT.com
Wishlist
2-Power Universal Camera Battery Charger
2-Power Universal Camera Battery...
£20.82
More than 50 in stock
£20.82
Add to wishlist
Delivery
Standard 3-5 working days
2-Power Universal Battery Charger
Universal Battery Charger suitable for charging many types of low voltage battery packs for Cameras, Camcorders, Mobile Phones etc. Simply adjust the charging pins manually to correspond to your batterys contacts and plug in to the mains or DC Car socket to begin charging. The charger automatically senses positive and negative polarity and is suitable for charging 3.6v, 3.7v, 7.2v & 7.4v Lithium ion Battery Packs.
The unit is also able to charge AA & AAA NiMH recharegable batteries and USB enabled devices via the 5V 1000mA USB port.
2-Power Universal Battery Charger - power adapter and battery charger - AC / car
Power adapter and battery charger - AC / car
6.8 cm x 2.9 cm x 11.8 cm
132 g
United Kingdom
Output Connector Type
USB (power only)
AC 230 V
Voltage Provided
5 V
1 year warranty
6.8 cm
2.9 cm
11.8 cm
132 g
United Kingdom
AC 230 V
Input Connectors
Power 3-pole, power DC jack
Voltage Provided
5 V
Output connectors
4 pin USB Type A (power only)
Max Electric Current
1000 mA
Supported Battery
AA, AAA
Nickel Metal Hydride, Lithium Ion
Limited warranty - 1 year
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.86
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
