BT.com
Wishlist
2-Power AC Adapter 19.5V 3.33A 65W Includes Power Cable
2-Power AC Adapter 19.5V 3.33A 65W...
£26.53
5 in stock
£26.53
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
2-Power - power adapter - 65 Watt
Power adapter - external
288 g
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Power Capacity
65 Watt
11.3 cm x 3.4 cm x 2.6 cm
1 year warranty
HP 255 G3; Envy 14, 15; Pavilion 17; Split x2
Input Voltage
AC 110-240 V
Output Voltage
19.5 V
Max Electric Current
3.33 A
Power Capacity
65 Watt
Limited warranty - 1 year
11.3 cm
3.4 cm
2.6 cm
288 g
HP 255 G3 , HP Envy 14-1001tu, 14-1050ea, 14-1095la, 14-1100el, 14-1101eg, 14-1110ew, 14-1110NR, 14-1111ef, 14-1111NR, 14-1114ef, 14-1120es, 14-1150ca, 14-1150es, 14-1154ca, 14-1155ca, 14-1160SE, 14-1163SE, 14-1180es, 14-1190ea, 14-1190eg, 14-1190eo, 14-1191ez, 14-1193eo, 14-1195ea, 14-1195eo, 14-1195la, 14-1196ea, 14-1196LA, 14-1199ez, 14-1200ea, 14-1200eg, 14-1200en, 14-1201ea, 14-1210eb, 14-1210NR, 14-1212ef, 14-1212tx, 14-1240eo, 14-1240ep, 14-1250ed, 14-1260eo, 14-1260es, 14-1260SE, 14-1290eo, 14-2000EA, 14-2000eg, 14-2002ea, 14-2012tx, 14-2014eo, 14-2020ew, 14-2020NR, 14-2030eb, 14-2050ed, 14-2050se, 14-2054se, 14-2070ez, 14-2070nr, 14-2080eo, 14-2090ca, 14-2090ef, 14-2090eo, 14-2095en, 14-2096la, 14-2099en, 14-2099sf, 14-2130nr, 14-2136nr, 14-2160ca, 14-2160se, 14-2166SE, 14-2195la, 14-3000ea SPECTRE, 14-3000eg SPECTRE, 14-3010NR Spectre, 14-3010tu, 14-3011tu, 14-3090ca, 14-3090LA, 14-3100eb Spectre, 14-3100ef SPECTRE, 14-3100eg SPECTRE, 14-3100el SPECTRE, 14-3100eo SPECTRE, 14-3100es SPECTRE, 14-3115tu SPECTRE, 14-3190la SPECTRE, 14-3210nr, 14-k010la, 14-k012la, 15-1150nr, 15-3005TX, 15-3012TX, 15-3023tx, 15-3040nr, 15-3047NR, 15-3090CA, 15-3090la, 15-3202tx, 15-3217NR, 15-3247NR, 15-3290LA, 15-j000ea, 15-j000eb, 15-j000ec, 15-j000ew, 15-j001eo, 15-j001sb, 15-j001sg, 15-j002eg, 15-j002er, 15-j002la, 15-j003eo, 15-j003la, 15-j003sg, 15-j004la, 15-j005ep, 15-j005ss, 15-j005TU, 15-j006ss, 15-j007eo, 15-j007ss, 15-j009eo, 15-j009ss, 15-j011nr, 15-j011sg, 15-j012eo, 15-j012la, 15-j013cl, 15-j013sg, 15-j017sg, 15-j019eo, 15-j020eo, 15-j022el, 15-j023c, 15-j028eo, 15-j030eb, 15-j030us, 15-j031nr, 15-j031ss, 15-j032nr, 15-j035eo, 15-j035so, 15-j037el, 15-j040el, 15-j040eo, 15-j059nr, 15-j060us, 15-j063ei, 15-J069SF, 15-j071sf, 15-j078ez, 15-j079sf, 15-j081eg, 15-j084nr, 15-j089sf, 15-j100eb, 15-j101el, 15-j101sf, 15-j103el, 15-j10us, 15-j112tx, 15-j130eb, 15-j150ed , HP Pavilion 17-e113dx , HP Split x2 13-m103ss
Scroll to top
