BT.com
Wishlist
Zyxel SBG3300-N000 Annex A VDSL2 /ADSL2+/GE WAN VPN Gateway
Delivery
Standard Due date unavailable
The ZyXEL SBG3300-N series applies ACL rules, Stateful Packet Inspection (SPI), Denial of Service (Dos) and DDoS features for first-line defense against hackers, network intruders and other harmful threats. A configurable DMZ provides more flexible accessibility while preventing external attacks on confidential databases.
The SBG3300-N series additionally features IPSec VPN which empowers companies to provide secure connections to branch offices, partners, road warriors and telecommuters. They can use L2TP or PPTP VPN to safely access corporate networks without having to install VPN software.
ZyXEL SBG3300-N - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Concurrent IPSec VPN tunnels: 20 , Simultaneous NAT sessions: 16000 , ACL rules: 256
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, IPoE, FTP
Routing Protocol
RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, TR-069
Firewall protection, DMZ port, NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, MAC address filtering, IPv6 support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), IPSec passthrough, Wireless Guest Services, VPN failover, WAN failover, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, port forwarding, DHCP relay, 3G/4G USB Dongle Support, DHCP client, NetUSB support, dual firmware images
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
21 cm x 11.5 cm x 3.3 cm
495 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
300 Mbps
MAC Address Table Size
2014 entries
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, TLS, SHA-1, TTLS, TKIP, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, FCC Part 15 B, IEC 60950-1, EN 60950-1, VPNC certified
Status Indicators
Power, WLAN, WAN, LAN, USB, ADSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.993.1, ITU G.993.2, ITU G.992.5 Annex A
Max Transfer Rate
100 Mbps
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
3 dBi
External power adapter
18 Watt
United Kingdom
21 cm
11.5 cm
3.3 cm
495 g
20 - 95% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.79
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.03
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.27
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.48
£39.19
Scroll to top
