BT.com
Wishlist
Zyxel PL-100 - HomePlug 1.0, HomePlug 1.0 with Turbo - external
Delivery
Standard Due date unavailable
The ZyXEL PL-100 PowerLine HomePlug 85Mbps creates a simple home network. This is ideal for gaming, streaming audio and video and Internet connectivity. It will allow your home to be completely networked using your existing plug sockets, with no need for additional wiring.
Zyxel PL-100 - bridge - desktop
Bridge
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug 1.0, HomePlug 1.0 with Turbo
Data Transfer Rate
85 Mbps
56-bit encryption, auto-uplink (auto MDI/MDI-X)
HomePlug 1.0
10.6 cm x 11.2 cm x 3.4 cm
162 g
2 years warranty
Bridge
Enclosure Type
Desktop
Wired
Data Transfer Rate
85 Mbps
Encryption Algorithm
DES
HomePlug 1.0, FCC Class B certified, UL, cUL, RoHS
Status Indicators
Power, link OK
1 x HomePlug 1.0 , 1 x 10Base-T/100Base-TX - RJ-45
10.6 cm
11.2 cm
3.4 cm
162 g
45 °C
20 - 95%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Connection question
Reviewed by Peterpiper on 03/04/2010
Do I plug one upstairs where my router is and connect them both by cable then put the other downstairs and plug into the mains then run a cable from it to my computer ?
Scroll to top
