Click to visit BT.com
Y-cam YCW004 CMOS Low Light Mode Box Camera
Y-cam Y-cam YCW004 CMOS Low Light Mode Box Camera
Usually dispatched within 3 working days
Quicklinx: 7XFTWS00
Mfr#: YCW004
£143.50
Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP Video Cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
The Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
The Y-cam White S can be wall-mounted, ceiling-mounted or placed on a flat surface using the supplied camera stand.
Y-cam White S - network camera
Network camera - fixed
Wired, wireless
8.5 cm x 3 cm x 8.5 cm
150 g
Camera
Optical Sensor Type
CMOS - 1/4" - 310,000 pixels
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Audio Support
Yes : built-in microphone
DC 5 V
Motion sensor, auto exposure control, auto white balance, auto gain control
1 x network cable
Stand
Environmental Parameters (operating)
-5 °C ... 45 °C ; 20 - 80% (non-condensing) relative humidity
Network camera
Wired, wireless
8.5 cm
3 cm
8.5 cm
150 g
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, ASF, 3GPP
Max Digital Video Resolution
640 x 480
Video Capture
640 x 480 @ 30 fps
Still Image
640 x 480 - up to 30 frames per second
Audio Support
Image Sensor
CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Angular Field of View (degree)
53.4 x 40
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g - DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, RTCP, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
1 x network cable
Power Requirements
DC 5 V
Power adapter - external 3.25 Watt
Software Included
Drivers & Utilities
Operating Temperature
-5 °C ... 45 °C
Relative Humidity (operating)
feature value
Brand Y-cam
Price Range Inc VAT 100 - 150
