Click to visit BT.com
Y-cam IP Camera Wifi LAN White SD
Y-cam Y-cam IP Camera Wifi LAN White SD
Usually dispatched within 3 working days
Quicklinx: 6MD0WS00
Mfr#: YCW003
£149.98 inc VAT
Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP video cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
The Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
Monitor and record live video and audio from anywhereYou can view live video with sound from virtually anywhere in the world as long as you have a computer, a web browser and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
Using the built-in microSD card slot, the Y-cam White SD no longer needs to be connected to a network or the Internet to store streaming video or motion alerts. Use the camera anywhere, even remote locations, and store video straight to microSD card, which is then viewable in your mobile phone, or via connection to a TV or PC.
Unlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Quick and simple setupDue to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP video cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
  • High quality video with soundThe Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
  • Monitor and record live video and audio from anywhereYou can view live video with sound from virtually anywhere in the world as long as you have a computer, a web browser and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
  • Record video or motion alerts to microSD card for local backupUsing the built-in microSD card slot, the Y-cam White SD no longer needs to be connected to a network or the Internet to store streaming video or motion alerts. Use the camera anywhere, even remote locations, and store video straight to microSD card, which is then viewable in your mobile phone, or via connection to a TV or PC.
  • MPEG-4 compression for reduced bandwidth and storageUnlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Mobile viewingWith support for MJPEG and 3GPP the camera provides a live view for multiple platforms, including Apple Macs, and mobile devices including the iPhone and Blackberry. The Y-cam's live stream can be viewed using any mobile phone that can play VLC-compatible streams, such as Quicktime and RealPlayer.
  • Multi-client access and password protectionThe Y-cam supports up to 16 simultaneous remote users. This allows easy and efficient video conferencing with minimum setup. Password protection also ensures no one able to access the cameras without authorization.
  • Secured wireless connectivityThe Y-cam can connect directly to a network or the Internet, either over Wireless (802.11b/g) networking, or over 10/100 with the supplied network cable. The Y-cam utilizes encryption methods such as WEP, and even the more powerful WPA and WPA2, so you can be sure your camera will only be accessed by authorized users.
Y-cam White SD - network camera
Network camera - fixed
Wired, wireless
8.5 cm x 3 cm x 8.5 cm
150 g
Camera
Optical Sensor Type
CMOS - 1/4" - 310,000 pixels
Minimum Illumination
1 lux
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Audio Support
Yes : built-in microphone
DC 5 V
Motion sensor, auto exposure control, auto white balance, auto gain control, microSD card slot
Apple MacOS X 10.4, Microsoft Windows 2000/XP/Vista/7
Stand
Environmental Parameters (operating)
-15 °C ... 45 °C ; 20 - 95% relative humidity
Network camera
Wired, wireless
8.5 cm
3 cm
8.5 cm
150 g
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG
Max Digital Video Resolution
640 x 480
1 lux
Video Capture
640 x 480 @ 30 fps
Still Image
JPEG - 640 x 480, 320 x 240, 160 x 120 - up to 30 frames per second
Audio Support
Image Sensor
CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Angular Field of View (degree)
53.4 x 40
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g - DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Compatible Slots
1 x microSD
Stand
Power Requirements
DC 5 V
Power adapter - external 3.75 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium III - 800 MHz - RAM 128 MB , MacOS X 10.4 - PowerPC G4 - 800 MHz - RAM 128 MB
Operating Temperature
-15 °C ... 45 °C
Relative Humidity (operating)
20 - 95%
feature value
Brand Y-cam
Price Range Inc VAT 100 - 150
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
