Click to visit BT.com
Y-cam Bullet IP Camera Wifi LAN
Y-cam Y-cam Bullet IP Camera Wifi LAN
Usually dispatched within 3 working days
Quicklinx: 6MD5WS00
Mfr#: YCBL03
£426.33 inc VAT
Easy to install, simple to operate, the high-performance Y-cam Bullet camera operates independently, without the need to be connected to a computer, in full color and infrared nightvision.
View and hear, in real time, from anywhere in the world, via any Internet-enabled computer or phone. If any motion is detected, the camera can instantly email you a snapshot, or record the video to a microSD card.
Image gallery
Select any thumbnail below to view a larger image.
  • Monitor and record live video and audio from anywhereYou can view live video with sound from virtually anywhere in the world as long as you have a computer, a web browser and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
  • High quality video with soundThe Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
  • Quick and simple setupDue to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP video cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
  • Infrared night visionThe Y-cam Bullet utilizes 12 infrared LEDs to provide high levels of "invisible" light in dark environments. The intelligent photosensitive components can automatically turn on the LEDs in low light conditions, or the user can select "moonlight view" which superimposes frames together to increase brightness (frame integration).
  • Infrared cut filterProducing true day and night quality images - Infrared light is filtered during day time operation to produce true color representation of the image. During night time operation the filter is removed to allow the camera to make full use of its night vision capabilities.
  • Fully weatherproofed for reliable outdoor useThe Bullet is the first true outdoor camera from Y-cam - its fully waterproof, and has shielded cables and seals to ensure smooth operation.
  • Professional grade connectorsComplete with Power over Ethernet, a Digital I/O and 2-way audio connectors, the Bullet is the ideal solution for systems integration.
  • Motion detection alerts via emailThe Y-cam comes with useful alarm tools that will keep you notified if any motion is detected. It has built-in functions that can generate alarm triggers via email and by uploading images straight to a website. Unlike conventional activity detection, the Y-cam uses vector information to detect motion, therefore achieving better reliability against false alarms.
  • Record video or motion alerts to microSD card for local backupUsing the built-in microSD card slot, the Y-cam Bullet no longer needs to be connected to a network or the internet to store video or motion alerts. Use the camera anywhere, even remote locations, and store video straight to microSD card, which is then viewable later in your mobile phone, or via connection to a TV or PC. It's a self contained detection and recording device.
  • MPEG-4 compression for reduced bandwidth and storageUnlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Mobile viewingWith support for MJPEG and 3GPP the camera provides a live view for multiple platforms, including Apple Macs, and mobile devices including the iPhone and Blackberry. The Y-cam's live stream can be viewed using any mobile phone that can play VLC-compatible streams, such as Quicktime and RealPlayer.
  • Multi-client access and password protectionThe Y-cam supports up to 16 simultaneous remote users. This allows easy and efficient video conferencing with minimum setup. Password protection also ensures no one able to access the cameras without authorization.
  • Secured wireless connectivityThe Y-cam can connect directly to a network or the Internet, either over Wireless (802.11b/g) networking, or over 10/100 with the supplied network cable. The Y-cam utilizes encryption methods such as WEP, and even the more powerful WPA and WPA2, so you can be sure your camera will only be accessed by authorized users.
  • Compact designThe Y-cam Bullet can be wall or ceiling-mounted, and is supplied with a sturdy connection bracket for easy alignment.
Y-cam Bullet - network camera
Network camera - fixed
Wired, wireless
19 cm x 7 cm
0.7 kg
Camera
Colour - Day&Night
Optical Sensor Type
CMOS - 1/4" - 310,000 pixels
Minimum Illumination
1 lux
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Audio Support
Yes : built-in microphone
DC 12 V
Motion sensor, auto exposure control, auto white balance, auto gain control, 12 infrared LEDs, microSD card slot
Apple MacOS X 10.4, Microsoft Windows 2000/XP/Vista/7
Environmental Parameters (operating)
-5 °C ... 45 °C ; 20 - 80% relative humidity
Network camera
Wired, wireless
19 cm
7 cm
0.7 kg
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG
Max Digital Video Resolution
640 x 480
1 lux
Video Capture
640 x 480 @ 30 fps
Still Image
JPEG - 640 x 480, 320 x 240, 160 x 120 - up to 30 frames per second
Audio Support
Image Sensor
CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Angular Field of View (degree)
60 x 45
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g - DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Compatible Slots
1 x microSD
Power Requirements
DC 12 V
Power adapter - external 4.5 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium III - 1 GHz - RAM 256 MB , MacOS X 10.4 - PowerPC G4 - 800 MHz - RAM 128 MB
Operating Temperature
-5 °C ... 45 °C
Relative Humidity (operating)
20 - 80%
feature value
Brand Y-cam
Price Range Inc VAT 300 - 500
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
