WD Scorpio Blue drives offer high-performance, low power consumption, and cool operation, perfect for notebooks and other portable devices. Pick the drive that suits your needs with the confidence in knowing that all WD Scorpio Blue drives are built to the highest standards of quality and reliability.
Massive capacity
Storage capacity for 2.5-inch form factor drives with standard 9.5 mm height has arrived at a realm once thought to be impossible - up to 1 TB* - giving you all the capacity you need to keep your photos, music and files right there on your notebook.
Quiet
In a notebook drive, silence is golden. WD's exclusive WhisperDrive™ combines state-ofthe- art seeking algorithms to yield one of the quietest 2.5-inch hard drives on the market. These algorithms also optimize the way a drive seeks for data, which significantly improves power consumption. So now silence (and longer battery life) is golden.
Reliable
WD's SecurePark™ parks the recording heads off the disk surface during spin up, spin down, and when the drive is off. This ensures the recording head never touches the disk surface resulting in improved long term reliability due to less head wear, and improved nonoperational shock tolerance.
Rugged
WD's ShockGuard™ technology protects the drive mechanics and platter surfaces from shocks.
Tested for compatibility
We perform tests on hundreds of systems and a multitude of platforms in our FIT Lab™ and Mobile Compatibility Lab to give our customers confidence that our drives will work in their systems.
Advanced Format (AF)
Technology being adopted by WD and other drive manufacturers to increase media format efficiencies, thus enabling larger drive capacities. (PVT models only)
Product Description | WD Blue WD10JPVT - hard drive - 1 TB - SATA 3Gb/s | Type | Hard drive - internal | Capacity | 1 TB | Form Factor | 2.5" x 1/8H | Interface | SATA 3Gb/s | Data Transfer Rate | 300 MBps | Buffer Size | 8 MB | Spindle Speed | 5400 rpm | Features | Shock Guard, WhisperDrive, SecurePark, Advanced Format technology | Dimensions (WxDxH) | 70 mm x 100 mm x 9.5 mm | Weight | 110 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 1 TB |
Width | 70 mm |
Depth | 100 mm |
Height | 9.5 mm |
Weight | 110 g |
Performance | |
Drive Transfer Rate | 300 MBps (external) |
Internal Data Rate | 150 MBps |
Average Latency | 5.5 ms |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 3 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" x 1/8H |
Software & System Requirements | |
OS Required | Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7 |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 8 - 95% (non-condensing) |
Shock Tolerance | 400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating) |
Sound Emission | 22 dBA |
The following resources are available for the WD 1TB Scorpio Blue 2.5" SATA 3Gb/s 5400RPM 8MB 9.5mm
