Click to visit BT.com
Western Digital 1TB Elements Desktop USB (WDBAAU0010HBK-UESN)
Western Digital Western Digital 1TB Elements Desktop USB (WDBAAU0010HBK-UESN)
Quicklinx: 6CTBWS00
Mfr#: WDBAAU0010HBK-UESN
Easy-to-use, reliable way to add more storage
£84.99
WD Elements Desktop 1 TB Hard Drives
WD Elements USB 2.0 external hard drive is an easy-to-use, reliable way to add more storage to your PC or Macintosh. Simply plug it in to a USB port and start saving or backing up your photos, music, video, and files. It's preformatted for immediate use so there's no software or CD to load. The compact, durable metal case provides extra data protection helping keep data safe from loss.
WD Elements Desktop WDBAAU0010HBK - hard drive - 1 TB - USB 2.0
Hard drive - external ( desktop )
1 TB
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
Included AC adapter
12.5 cm x 20.4 cm x 3.6 cm
1.02 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 TB
USB 2.0
12.5 cm
20.4 cm
3.6 cm
1.02 kg
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Power Source
Included AC adapter
Power adapter
AC 120/230 V ( 50/60 Hz )
Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB cable - external
RoHS
5 °C
35 °C
feature value
Form Factor 3.5"
Capacity 1TB
Interface Hi-Speed USB
Brand Western Digital
Stock Status Clearance
Price Range Inc VAT 50 - 100
