BT.com
Wishlist
WD Red 4TB NAS Desktop  Hard Disk Drive - Intellipower SATA 6 Gb/s 64MB Cache 3.5 Inch - WD40EFRX
WD Red 4TB NAS Desktop Hard Disk...
£149.98
14 in stock
£149.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
WD Red NAS Hard Drive WD40EFRX - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
680 g
3 years warranty
My Cloud EX2; EX4
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.5 Watt (read) , 4.5 Watt (write) , 3.3 Watt (idle) , 0.4 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
25 dBA
WD My Cloud EX2 , WD My Cloud EX4
WD Red 4TB NAS Desktop Hard Disk Drive - Intellipower...
£149.98
Save on this ideal PC Build kit!
Save £16.72
£175.15
Cables - Cables
£149.98
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.24
£153.22
Accessories
£37.11
£87.73
£89.43
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Poor packaging - DOA
Reviewed by Cris on 17/06/2014
I'd like to echo the previous review. I ordered two of these and they arrived each in the standard anti static bag inside a thin cardboard wrap, both were delivered inside one of those grey plastic parcel bag things. No bubble wrap at all. One was a DOA and I'm really surprised both weren't dead considering they way they were shipped. I will be keeping a close eye on the second drive from this order. Once again I would suggest BT take a look at the way they send out HDDs before WD/Seagate etc start asking questions regarding the number of returns they're being sent. I chose to return the drive with an anti static bag, inside the cardboard wrap and in a box full of packaging noodles, be nice if my replacement was sent the same way! You can even use the same box again! ;) Rating the product high, but would mark the shipping as 1.
Our response
Thanks Cris, as per my other comment response, we've taken action on the basis of feedback and hope to have erradicated the issues packaging has been causing for customers. UPDATE: Sept 2014: these issues have now been fully addressed and rectified with appropriate packaging.
5* Poor packaging - DOA part 2
Reviewed by Cris on 20/03/2015
In reference to my first review: Reviewed by Cris. Review Posted 17/06/2014. My replacement drive was packaged in EXACTLY. THE. SAME. WAY. Not improved packaging here. I'm looking for more drives for my NAS so thought I'd add this here for others quickly, I'd never buy a drive from BT. Another of these drives is now failing in my NAS and I attribute that entirely to the way it was shipped. 2 out of 3 failures, thanks BT. BT didn't, and from more recent reviews, appear still have not fixed this. It's just an email to the warehouse guys, how hard is that?
Our response
Hi Cris, have dropped you an email to discuss, we have most definitely improved this and concenred as to what packaging you received. Thanks, Dunc
5* Great drives
Reviewed by M Harrison on 12/12/2015
I have two Netgear NAS systems and they were populated with 2TB WD "Green" drives which performed well enough. Once I needed to expand the required space I decided to try the 4TB "Red" drives (the NAS systems can't handle the 6Tb ones :( ) and it was a good choice. They are just as quiet as the "Green" drives and, more importantly, noticeably faster :) I've been swapping them out one by one since I can't fund swapping them all at once and I've had no problems :) - Some of them have been in use for a couple of years now and I've had no issues with any of them... :)
I didn't have the packaging issues mentioned by other people.
5* Packaging poor
Reviewed by Anonymous on 04/07/2014
I haven't tried the two drives I've just purchased - fingers crossed the're all ok. The packaging is as described by the previous reviewer - carboard in a plastic bag. Nothing to absorb shock. For something like this bubble wrap is the obvious safe choice. Until this improves, no more purchases from BT for me.
Our response
Hi, thank you for your review. I've dropped you a full response via email however please note we read all feedback from our customers and in this instance I wanted to ensure you were aware it’s a known issue that we are taking steps to rectify. Since receiving some feedback from our customers in recent weeks we have taken steps to investigate and I want to assure you we are in the process of overhauling the packaging we send our HDDs out in and have a temporary measure in place to improve the protection of all drives that get despatched. Hopefully with this knowledge you can see our commitment to improving customer experience and not be dissuaded from buying from dabs.com again soon. Thanks, Dunc UPDATE: Sept 2014: these issues have now been fully addressed and rectified with appropriate packaging.
3* Poor packaging - risks damage
Reviewed by Tom T on 15/06/2014
This is a quality product but appears to be supplied to BT in a thin cardboard wrapper. BT than post it out in a thin single sheet bubble wrap envelope. Not surprisingly 1 out of the 4 I ordered was DOA. The WD returns procedure specifies you must use 2 inches of bubble wrap. Such a shame all these expensive electronics devices are being wasted through poor packaging procedures by the manufacturer and the retailers.
Our response
Hi Tom, thanks for your feedback. I'd like to update you to the fact we have recently made some changes after customer feedback to HDD packaging and have taken steps to ensure it's now vastly improved to ensure issues like yours do not happen again. Once again we take customer feeback very seriously and always aim to take action to improve our processes and procedures. UPDATE: Sept 2014: these issues have now been fully addressed and rectified with appropriate packaging.
1* DOA due to bad packaging
Reviewed by Carl on 04/01/2015
Unfortunately, dispute the previous notes about improved packaging my drive arrived in a cardboard carton with only a thin layer of form wrapped around it. The result is that the drive was faulty and locked up my NAS at around 5% into the formatting process.
Our response
These issues have now been fully addressed and rectified with appropriate packaging.
Scroll to top
