Click to visit BT.com
Vision SP-1300 Pair Wall Speakers Black
Usually dispatched within 3 working days
Quicklinx: 676FWS00
Mfr#: SP-1300B
£61.20
New to the Vision range are the new SP-1300 loudspeakers, designed to compliment the AV and C range of Vision audio amplifiers. Optimized for presentations, these high-quality speakers output clear, intelligible audio with a wide dispersion to cover wide areas. Achieve high sound pressure levels with clarity.
Vision SP-1300 - left / right channel speakers
Left / right channel speakers
16 cm x 12 cm x 23 cm
1.7 kg
System Components
2 speakers
Speaker Type
2-way - passive
Nominal (RMS) Output Power
70 Watt
Response Bandwidth
80 - 20000 Hz
Input Impedance
8 Ohm
Wired
Speaker System Details
2 x right/left channel speaker - 70 Watt - 80 - 20000 Hz - 8 Ohm
2 years warranty
16 cm
12 cm
23 cm
1.7 kg
Enclosure Colour
Speaker System
System Components
2 speakers
Speaker Type
2-way - passive
70 Watt
Response Bandwidth
80 - 20000 Hz
Input Impedance
8 Ohm
Sensitivity
86 dB
Wired
Recommended Placing
Wall-mountable
Additional Features
Corrosion resistant, vandal resistant
Speakers Included
2 x right/left channel speaker - 2-way - 70 Watt - 80 - 20000 Hz - 8 Ohm - wired
Driver Details
Right/left channel speaker : 1 x woofer driver - 4" , Right/left channel speaker : 1 x tweeter driver - 3/4" - silk
Wall mounting brackets
2 years warranty
Service & Support Details
Limited warranty - 2 years - carry-in
feature value
Accessory Type Speakers
Brand Vision
Price Range Inc VAT 50 - 100
